Re: Ive got a couple of problem s, but first I need to get water balanced........?
yes I do have the Taylor K-2006.
I have now vacuumed pretty much all that I can. The rest is such small particles it will be left up to the skimmer sock to catch. Sock has to be cleaned roughly every 2-3 hrs so its definitely still catching stuff. The pool is blue and I can easily see the bottom. Even the cloudiness has went away but its not a crystal clear look yet. I will check the FC and ph in the morning and see if its holding............If it is then we can assume thats pollen?
I checked my tablets and they say 98.6% trichloro-s-triazinetrione. So is it adding CYA or not? My CYA levels are too low I think(less than 30) so I was gonna use the 3" tablets until it reached 40 or 50 then switch back to bleach......Is my thinking realistic?
24 round 12-14K gal AG vinyl pool; chlorine tabs and bleach; 300lb Hayward sand filter; Hayward 1 HP 2-speed pump; K-2006
