Results 1 to 3 of 3
Thread: intex on concrete
    Jun 2013
    usa
    Default intex on concrete
    Im having a pad poured for my 14' ultra frame. pad will be level,checked with a water level. I cant find any info on setting up on concrete. how thick should the pad be. what is needed under the liner and anything else I might need to know.
    the pool is only up in the summer then removed for winter.
    thanks for the help
    Default Re: intex on concret
    I don't know how thick the pad should be--in part I think it depends on what's UNDER the pad. Intex used to sell a polyvinyl tarp, 16x16, that you put down first before you erected the pool.
    BigDave's Avatar
    Jul 2010
    New Jersey
    A thin (1/4") layer of foam insulation on the pad should help protect the pool from sharp irregularities in the concrete surface.
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
