Results 1 to 5 of 5
Thread: Test interference
    cygnusecks is offline Unconfirmed User Thread Analyst cygnusecks 0
    Orlando, FL
    Default Test interference
    Whenever I get a water sample for a test, I try to stay away from the returns, and I always take the sample from as deep as I can go with my arm/hand... which got me thinking. Can residue or other stuff on my hand interfere with the test? For example, suppose I hold the sample bottle by the neck, dip it into the water, and turn it right side up. The water flowing into the sample container will be "filtering" through my hand/fingers. What if I had just eaten an orange or done a load of laundry? Will the residue somehow affect my testing? Am I being too paranoid?
    Maine, USA
    Default Re: Test interfererence
    What I do is wait for an approximate "turn-over' of the water before testing.
    Other than that yeah, I think you're being too paranoid
    Regards,
    Ron [ muvipix.com ]
    Orlando, FL
    Ok, thanks. I also usually test in the evening after a full day of circulation/filtering.
    I also need to learn how to spell INTERFERENCE :-)
    Honesdale PA
    Default Re: Test interference
    I take the sample from about a foot down in front of the skimmer. If you have a chlorinator or salt chlorine generator or any other chemical thing the chemical levels at the returns can be off. Since I throw all chemicals in the skimmer there is a chance that some stuff can still be dissolving in the sand filter too.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. Radio Frequency Interference
    By rkisko in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-16-2010, 10:00 PM
  3. Radio Frequency Interference
    By rkisko in forum In-Ground Pool Construction and Repair
    Last Post: 09-16-2010, 06:06 PM
  4. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  5. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
