Results 1 to 10 of 39
Thread: Getting ready to open 40k gal pool AKA "the Swamp"
    May 2014
    Oklahoma
    Default Re: Getting ready to open pool
    I haven't received my test kit yet. I have been hearing this strange noise for the past week or so, last night I went out to see what it was and discovered we have frogs in our pool! Today I added some water and started to clean out slimey disgusting leaves, possible frog eggs and I don't know what else that was floating in the water. I can see maybe a foot in the water, it is bad. I need to add more water tomorrow before I can think about turning it on but is that still my plan, to turn it on and test? It has never been this bad before but I guess I have seen bleach perform miracles! I may call around and see if I can find someone with a pump to clean out the bottom so it doesn't have to go through the filter. I have a cartridge filter and can't pump to waste. We would be cleaning the cartridges every 5 minutes!
    IG free-form concrete pool 40,000 gal Sta-Rite cartridge filter
    Try and scoop out as much as you can manually. And if was my pool, I'd do it quick before you have tadpoles! That would be a pain to try and fish them out!
    Good luck!
    May 2014
    Oklahoma
    I am adding more water right now. I have removed all of the floating debris but I can't see the bottom. I'm sure it's nasty, should I just blindly dig around down there before I turn it on? Should I dump a bunch of bleach in and manually stir to clear a bit and possibly see the bottom before turning on? Everything is so slimy, I don't know why it's so bad this year!
    Try and just net out what you can first. When you get out as much as you can, go ahead and turn on equipment and add bleach.
    May 2014
    Oklahoma
    Ok, I'll get out as much as I can then turn on and test, UPS shows I will get it by end of the day tomorrow. Then you'll tell me how much bleach, right? I am going to buy a lot today so I'll be ready!
    Yes, someone here can help you get started especially after you can get some good water testing numbers. Take some pictures now so you'll have the before and after. You won't believe what bleach will do!
    May 2014
    Oklahoma
    After doing a lot of reading here I'm worried about how much bleach I will need to clean my swamp and all of that dirt and stuff going through the filter. I'm afraid we'll be cleaning the filter every 30 minutes! My husband says lets drain it and start over. Which would be more cost effective? Are we in an area where draining is a possibility? And of course, I just filled it full today! Have not turned it on yet, I am still waiting for the test kit. Can you tell I have read too much and scared myself? Should I just wait to decide anything until I can test? I am just thinking about last season and how I couldn't keep chlorine in the pool and what if the cya has turned to ammonia, the what ifs are getting to me!
