Try and scoop out as much as you can manually. And if was my pool, I'd do it quick before you have tadpoles! That would be a pain to try and fish them out!
Good luck!
Good luck!
I am adding more water right now. I have removed all of the floating debris but I can't see the bottom. I'm sure it's nasty, should I just blindly dig around down there before I turn it on? Should I dump a bunch of bleach in and manually stir to clear a bit and possibly see the bottom before turning on? Everything is so slimy, I don't know why it's so bad this year!
IG free-form concrete pool 40,000 gal Sta-Rite cartridge filter
Try and just net out what you can first. When you get out as much as you can, go ahead and turn on equipment and add bleach.
Ok, I'll get out as much as I can then turn on and test, UPS shows I will get it by end of the day tomorrow. Then you'll tell me how much bleach, right? I am going to buy a lot today so I'll be ready!
Yes, someone here can help you get started especially after you can get some good water testing numbers. Take some pictures now so you'll have the before and after. You won't believe what bleach will do!
After doing a lot of reading here I'm worried about how much bleach I will need to clean my swamp and all of that dirt and stuff going through the filter. I'm afraid we'll be cleaning the filter every 30 minutes! My husband says lets drain it and start over. Which would be more cost effective? Are we in an area where draining is a possibility? And of course, I just filled it full today! Have not turned it on yet, I am still waiting for the test kit. Can you tell I have read too much and scared myself? Should I just wait to decide anything until I can test? I am just thinking about last season and how I couldn't keep chlorine in the pool and what if the cya has turned to ammonia, the what ifs are getting to me!
Alright, I cleaned out as much as I could without being able to see. I turned everything on and discovered that my pressure gauge is busted, so I will get one tomorrow. I tested the water and heres what I got:
TC: 0
pH: more than 8, color was a very bright pink/fuschia
TA: 70
CH: 230
CYA: 0, black dot never disappeared, the water was just a tiny bit cloudy
So, I am going to add 12 gal. of 10% bleach, then I will check it in 4-6 hours? add more if its below what? 30 ppm is what I will go by until I hear from you but maybe I don't need it so high since I have no CYA? Well, I'll try to keep it at 30 for now only because its a bad looking swamp out there. The frogs are wondering whats going on. Should I plan on cleaning the filters tomorrow or get the gauge first so I can see the psi? I know they will be bad!
