Re: Getting ready to open pool
Alright, I cleaned out as much as I could without being able to see. I turned everything on and discovered that my pressure gauge is busted, so I will get one tomorrow. I tested the water and heres what I got:
TC: 0
pH: more than 8, color was a very bright pink/fuschia
TA: 70
CH: 230
CYA: 0, black dot never disappeared, the water was just a tiny bit cloudy
So, I am going to add 12 gal. of 10% bleach, then I will check it in 4-6 hours? add more if its below what? 30 ppm is what I will go by until I hear from you but maybe I don't need it so high since I have no CYA? Well, I'll try to keep it at 30 for now only because its a bad looking swamp out there. The frogs are wondering whats going on. Should I plan on cleaning the filters tomorrow or get the gauge first so I can see the psi? I know they will be bad!
IG free-form concrete pool 40,000 gal Sta-Rite cartridge filter
