Results 1 to 10 of 15
Thread: Pool automation
    Default Re: Pool automation
    The test that strips -- and dealers -- most often mess up badly is the CYA test.
    See if you can find an HTH 6-way: http://pool9.net/tk-hth6/
    If you can, use it to do the CYA test, and compare results. The videos for the K2006 apply to the CYA test in the HTH6: http://pool9.net/tk-guide/
    May 2014
    To overcome what i descibed above I was thinking on getting a colorimeter for at least the PH and the free clorine.
    Have been looking at the hanna ones but they seem not to be the most reliable either
    The Taylor K2006 does not use color matching for the chlorine test. You add a powder to a water sample which turns it pink. Then, you add drops until it turns clear. Your reading comes from counting drops, not matching a color.
    The only color match in the Taylor kit is the pH reading. Check this page: http://pool9.net/ph-meter/ to see if you need a pH meter.
    The Taylor K2006 does require you to notice a color CHANGE; these videos show you what you're looking for:
    http://pool9.net/tk-interfere/
