Results 1 to 10 of 46
Thread: 100,000 gal pool
    Default Re: 100,000 gal pool
    Yes.
    But you need to understand that you can expect to loose 15 ppm of FC weekly -- on your pool that translates into 15 pounds of cal hypo weekly . . . when everything is perfect.
    May 2014
    So Calif
    Smile Re: 100,000 gal pool
    What parameters are we looking for to be able to swim in the pool? It is not clear at the bottom of the deep end yet.
    It's looking so much better, thank you so much!
    90k gal concrete pool, Pentair DE FNS+ 60. Pentair Whisperflo 2 spd. PF=1.4
    Chlorine = to 10% of CYA level; pH between 7.0 and 8.0; no slime.
    BigDave's Avatar
    Also be concerned with cloudy water. If you can't see a swimmer on the bottom, you can't rescue him.
    May 2014
    So Calif
    Ok, thanks.
    May 2014
    So Calif
    Smile Re: 100,000 gal pool-it's clear now!
    My pool is clear!
    Thank you, thank you!
    To make sure it stays clear, please clarify what we need to do from this point. We have Cal-hypo and dichlor
    We're adding a gallon of 8% bleach after swimmers.
    Default Re: 100,000 gal pool-it's clear now!
    Looking at these results:
    Code:
    7/27/2014 18:30:00	32 psi
    K2006: 10.2, 1.0, 7.5, 140, 430,30
    blue	crystal clear	No odor	No algae	crisp, clean
    Brushed pool, Vacuumed pool, Cleaned filter, Added chemicals
    It looks like your water is in excellent shape, so:
    1. Maintain 2 - 5 ppm of FC
    2. Cal hypo is fine, but ONLY if you add it via the skimmer. Also, if you use cal hypo, you must let the pH 'float', unless it goes above 8.0
    3. Your CYA is low enough, so that you can also use trichlor. You might want to use trichlor in a floater, to maintain a constant feed, and dose with cal hypo in the evenings to boost chlorine levels.
    Note that trichlor and cal hypo must NEVER come into direct contact.
    4. You asked about paying -- if you'd like to do so, we'd certainly welcome a subscription: http://pool9.net/subscribe/
    Thanks!
