Closed Thread
Results 1 to 10 of 51
Thread: Intermatic Pool Timer Wiring
    Apr 2014
    Rancho Cordova, California
    Default Re: Intermatic Pool Timer Wiring
    I found instructions for testing a pool pump with a multi-meter at Inyo Pools website. I will test the pool pump this afternoon. Testing to check for a short across the windings sounds too complicated for me and way beyond my skill level. I don't have an amp-meter. If I have to replace my Pentair 3/4 HP Whisperflo single speed motor, can I buy a 3/4 two speed motor instead? Is the quality of an OEM motor equal to Pentair's replacement motors? I think the pool pump is at least a few years old. I have to see if there is a date on the pump and will update thread if its older.
    mas985's Avatar
    Pleasanton, CA
    Yes you can replace your current motor with a two speed. Is your pump the WF-3 or the WF-23?
    Pentair does not make motors, they usually use a branded A.O.Smith now branded as Century motors on their pumps which are also sold aftermarket.
    Mark
    The 2 speed motors are pretty expensive. Since you have a small pool, if your motor is shot, you might be better off getting a 2-speed above ground pump:
    Hayward SP15922S Power-Flo Matrix 2-Speed
    Here's a link for replacement motors:
    http://www.a1poolparts.com/-strse-Mo...Categories.bok
    Apr 2014
    I agree that buying a new pump is better than paying for a new 2 sp motor. It costs more than a new pump to replace the motor because I would have to buy some other parts to install it. I checked out the Hayward SP15922S and it is 1 Hp. The Pentair Whisperflo pump I have is 3/4 HP and it is too big for my 8190 gal pool. Would a 1 HP be ok or should I look for a 3/4 HP 2 speed pump?
    6.3k gal AG rectangle; Whisperflo 3/4 HP pump WF3; Pentair CCP-240 cartridge; Rainbow #320 Chlorine Feeder; Intermatic Timer; Solar Cover and reel; Taylor K2006 test kit. PF=19
    mas985's Avatar
    Pleasanton, CA
    Actually, the Whisperflo is a larger pump than the Matrix. You can't always go by label HP when sizing a pump, you have to compare head curves for a true measure of a pump's power. For example, on typical AG pool setup, the Whisperflo will deliver about 53 GPM but the Matrix will deliver only 50 GPM.
    Mark
    What he said.
    You could use a smaller pump, but as far as I know, an above-ground 3/4 HP with 2 speeds is not available.
    Apr 2014
    You are correct about the 2 speed 3/4 HP for above ground pools but they are available for in-ground pools. I bought a used above ground pool that came with an in-ground Pentair Whisperflo 3/4 HP (WFE-3 single speed) pump.
    Apr 2014
    I looked at the wires coming from the pump and they are thinner than the wires that I used to supply power. I have a GFCI outlet and added a 15A 125V three pronged plug to supply power to the Intermatic Pool timer and pump. If you look at the first or second page of this post you can see a picture of the wiring for the Intermatic. The wires from the pump are blue, blue, and white. The blue wire has 12 AWG and the wires that supply the power to the timer are for 15 amps 125V and are thicker. Would the smaller wire coming from the pool pump cause the overheating problem?
    mas985's Avatar
    Pleasanton, CA
    Possibly if the voltage drop was significant. But if the wire size is at least 14 gauge, that is sufficient for that pump.
    http://www.pentairpool.com/pdfs/WhisperFlo%20OM.pdf
    Mark
    Quote Originally Posted by sjeffers01 View Post
    If those wires were large enough to operate the pump successfully in the past, they are probably still large enough now. If you want more specific info, you need to check actual wire gauge.
Closed Thread
