Thread: Hayward Northstar pool pump will not turn on....
    Apr 2014
    Gilbert Az
    Default Hayward Northstar pool pump will not turn on....
    I had a mechanical switch and Aquarite saltwater system installed last week. Today I noticed when I went to turn on my pool pump that the breaker had been tripped and the pump is not turning on. When I flip the mechanical switch to "on" the motor in the pump does hum however it doesn't not activate.
    Any suggestions?
    Default Re: Hayward Northstar pool pump will not turn on....
    . . . membership updated.
    Could be a stuck impeller or motor bearings -- manually turning the impeller or the motor shaft can sometimes fix that. Another common cause is a bad capacitor.
    Are those tasks you want to tackle yourself?
    Apr 2014
    Gilbert Az
    Ben,
    Thank you for the response. I was able to manually move the impeller with no issues however the pump is not engaging but it does have power. Should I be worried about a possible bad install with wiring when my new salter water system and mechanical timer was installed last Thursday? It worked through this week with no issues. I used a reputable pool and install company to do it that I will call on Monday morning to check it out as the pump maybe just burned out. It was installed in 2006, although I dont know the typical life span of a Northstar system.
    Apr 2014
    Gilbert Az
    It was the capacitor..or is.
    The capacitor on the motor doesn't show the correct mfd as it has been smudged off. I will wait until Monday morning to talk to a professional. In the meantime I quickly turned on and off a 55Mfd to test and the pump and motor operated correctly.
    Glad it worked out for you!
    There's a fair chance you can find out the correct capacitor by calling Hayward -- hayward-pool.net .
    (Ya know, it's kind of disorienting to me sometimes, to be switching between people who don't know what a "common" wire is or what role it plays in a 120V circuit, and people who do know what a "micro-farad" is! )
    Jun 2013
    Central Florida
    "Micro farad" - Isn't that just a really REALLY small farad? (I crack myself up sometimes)
    Nah, it's just a 'little bit' of farad!
