Results 1 to 10 of 13
Thread: Water Balance: Adjust alkalinity first, then PH . . . Or Not
    BigDave's Avatar
    Default Re: Water Balance: Adjust alkalinity first, then PH
    Did you test TA after adding the first four pounds of baking soda? What was it? What was the pH?
    Mar 2014
    NC
    TA was down to 70 and pH was 7.2. Will test again this morning. ;-)
    Tested: TA up to 100 now and pH back to 7.4. Looks good to me now. Will do a full test todat after work.
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
