Results 1 to 10 of 15
Thread: Season Startup
    MD.
    Default Season Startup
    Hello everyone. I have been a successful BBB user since my 18k concrete pool was built 10 years ago. Just opened for the season and would like confirmation on what to balance first. Here are my numbers.
    FC / TC - 0
    PH -7.8
    CYA - 0
    TA - 40
    CH - 90
    Should I concentrate on the TA and CYA first ?
    Ollie
    May 2013
    Northwest Indiana
    Default Re: Season Startup
    Top priority is chlorine... Get some in there pronto. How much cya did you have when you closed in the fall?
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    MD.
    Thanks Eric.... Not sure about the CYA at closing. I have 4lbs left over from last season which I can add today along with chlorine...
    May 2013
    Northwest Indiana
    Hold off on that... If you had cya at close, but now there is none, it may have been converted to ammonia by bacteria... Shock your pool in the evening and see if your fc level holds overnight... PH is the second thing to focus on, but definitely start with chlorine
    MD.
    Thanks Eric.... Did not see your post before adding the 4lbs of stabilizer on Sunday , however, I have been holding TC at 5 since then. Here are my latest numbers using PS233 kit
    FC 8
    CC 0
    TC 5
    PH 7.2
    ALK 50
    CAL 300+ *may have old agents as the R-0011L barley turned Red and ran out of R-0012 before it changed to a 'Blue'
    CYA < 20
    Anxious to know your thoughts
    Thanks again
    Ollie
    It takes at least 48 hours if not longer for CYA to dissolve. Initially, your easiest route, ironically, would have been tri-chlor tabs! FC=0, pH=7.8, CYA=0? Trichlor adds FC, Acid and CYA.
    HOWEVER, at this point, I'd wait and see if CYA comes up. Otherwise...it is impossible to have FC = 8, CC= 0 and TC=5. because TC = FC + CC always, by definition.
    MD.
    Does Ben still sell these kits ?
    No. But, the kit we suggest is pretty much the same thing ---- Taylor K2006 or 2006C (better buy) and you can get it through the test kit link in my signature below. It takes you to an Amazon link. If you buy things from Amazon through that link, the forum make a little money which helps us keep the lights on.
    (By the way --- you can order other items besides pool supplies through that link. Once that link gets you to Amazon, you can simply search for what you need. Regardless of what you buy, if the sale starts through that link, the forum benefits from it.)
    MD.
    Thanks... Just ordered the 2006C.... Should I just trash the PS233 kit ? (How long will the 2006c kit last ?)
