We just moved into a place with a pool - and I've no idea, so I'm basically looking for an explanation of how the cleaning system works.
I'm aware - in principle - of the idea of both intakes and outlets on the pool floor - we also have outlets on the side of the pool in a couple of places.
For intake we also have what I believe is the skimming facility - a 'door' through which water flows into a cylindrical hole about eighteen inches deep at the bottom of which are two holes. If I turn the filter on, then suction comes through one of those holes (always the same one). I plug the vacuum into that and all is well - it cleans and water comes back into the pool via the outlets on the side (as far as I can determine, nothing is coming back into the pool via any outlets on the floor of it).
Part of the pool is a spa/hottub which has one floor intake, one floor output, and one wall output. When I vacuum water comes into that area via the wall output.
For what it's worth, before they left, the previous owners told my wife that "some of the popups" don't work. I don't know what "popups" are.
Our filter has a lot of pipes going this way and that, through which the water comes in and goes out, cleaned. There are no less than three (3) switches which can switch the flow of the water (in some way).
My questions are very general - what does the other hole at the bottom of the skimmer do? How can I know which of the switches to have which way? To run the skimmer, why do I need the white thing with the sliding gate, and how should I set it?
Apologies for the (a) dumbness and (b) probably lack of clarity of my questions, and thanks in advance for any help.
