Results 1 to 5 of 5
Thread: Test Kit
    May 2014
    Houston, TX
    Default Test Kit
    I'm going to purchase a test kit and was wanting know your thoughts on Taylor k-2005 and the Taylor k-2006c. I live in Houston Tx and have a 30,000 salt water ingound with a DE filter.
    Default Re: Test Kit
    The K2005 and K2006 are identical, except for the chlorine test. If chlorine levels are 5 ppm, both kits will show 5 ppm; but if levels are 10 ppm, the K2005 will still show 5 ppm, but the K2006 will show 10. It gets worse: if chlorine levels are 20 ppm, the K2005 will show ZERO, but the K2006 will show 20.
    Since you have to have high levels of chlorine to manage algae in outdoor stabilized pools . . . . this is a problem.
    As Mom said, get the K2006 (A model = 3/4 oz bottles; C model = 2 oz bottles.)
    May 2014
    Houston, TX
    Thank you for the advice. I just received my Taylor k 2006c.
    inground free-form pool
    Great!
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
