Thread: Hayward vari-flo multiport valve malfunctioning
    May 2014
    North Carolina
    Default Hayward vari-flo multiport valve malfunctioning
    New here, first time post.
    I have a Hayward Vari-Flo valve. We have been having trouble with the gasket getting pulled and stretched and have had to replace it the past two years. We recently replaced the gasket as well as the spring which was advised from somewhere else. The handle has a lot of play in it and is already "looks" as if it is depressed when it is not so when we press it to rotate there is not much room to depress it and is causing the gasket to bind still. What could be the problem. Could it be as simple as the gasket needs to be replaced just below the handle? Thanks
    Default Re: newbie?
    The handle / lid is a single assembly. If the handle is remaining depressed, even when you're not touching it, something is wrong with that assembly. I'd recommend taking the valve apart and inspecting it, but my guess is you need a new assembly.
    One tip: the assembly is spring loaded. Loosen all the bolt partially, before you remove any of them completely. Otherwise you will likely crack the lid.
  1. Replaced Hayward Vari-flo XL Valve
    By dcarlton in forum Pool Equipment & Operations
    Last Post: 05-07-2014, 11:36 PM
  2. Hayward Vari-Flo Control Valve Problem?
    By karrde97 in forum Pool Equipment & Operations
    Last Post: 05-21-2013, 10:56 AM
  3. Hayward Vari-Flo Multiport Vale Replacement question
    By raw23062 in forum Pool Equipment & Operations
    Last Post: 08-03-2011, 02:56 PM
  4. Hayward FIP Vari-Flo Valve hairline crack
    By isdsms in forum Pool Equipment & Operations
    Last Post: 04-22-2008, 10:02 AM
  5. Hayward multiport Vari-Flo valve leaking out the top
    By gworrel in forum Pool Equipment & Operations
    Last Post: 08-25-2007, 11:13 PM
