The handle / lid is a single assembly. If the handle is remaining depressed, even when you're not touching it, something is wrong with that assembly. I'd recommend taking the valve apart and inspecting it, but my guess is you need a new assembly.
One tip: the assembly is spring loaded. Loosen all the bolt partially, before you remove any of them completely. Otherwise you will likely crack the lid.
