Re: Newbie POOL person here...
Mike,
If your building a pool and spending upwards of $30K then look into SWGs!!!! They produce chlorine from the salt (you add) to the pool. Safe, maintains constant Cl levels once you have everything adjusted and will not add CYA like pucks/floaters. If our pool season was longer than 3 months and if I did not have to burn $$$ this season on new pool motor I would get one!! Search posts for SWG and read up!!!
Outside of Philadelphia, PA
18' x 40' IG - 22K gallons
Sylvan Gunite Pool (1979)
Plaster re-done (1997)
