Thread: Excess vermiculite
    May 2014
    NW Ohio
    Default Excess vermiculite
    Just had a liner put in our inground pool. It is a 19 x 36 Roman. After filling we noticed the incline edge from the shallow to the deep end was very rounded. Our PB told us when then came back to cut out the hole for the light that they could trowel this out. Is that possible? He also said if they couldn't trowel it out they would come back after the season, drain the water, fix the problem, and pay to refill the pool.
    I haven't paid the balance of my bill yet. Should I get all this in writing and pay the bill?
    Default Re: Excess vermiculite
    I wouldn't.
    It's generally a bad idea to pay 100% for work that's not 100% finished. I'd make a reasonable payment, based on the completion. If you are about to make a payment, leave unpaid a portion for the light and the leveling, based on the assumption that it will be the complex fix in the fall. Then pay for completion as it occurs.
    But . . . it's Ohio. It's cold. Why don't you postpone pool opening and have him fix it now? That way, it's not hanging over your head or his.
  1. Lime Softening to Reduce Excess Hardness - Bucket Test & Treatment Process
    By PoolDoc in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2012, 05:26 PM
  2. J-channel holding liner in corner broke off, liner is sagging
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 04:41 PM
  3. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  4. Excess Liner on J Hook installation Grrrr..
    By robot9000 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 10:14 PM
  5. Do I need "Liner Lock" for Beader Liner
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2006, 12:04 AM
