Thread: Using well water and historic problems with mustard algea
Threaded View
    May 2014
    Atlanta GA area
    Default Using well water and historic problems with mustard algea
    New forum user. Doughboy above ground 28 round 18000 gallons 225# sand filter with 1 hp pump. Just south of Atlanta.
    Believe my historic issues are caused by stabilizer buildup during the season using Bioguard and others 3 inch chlorine tabs.
    Ran between 0.5 to 0.9 ppm copper and still kept appearing last couple years. And leaves from pear and pecan trees!
    Used 4 bags of Bioguard cal hypo burn out at end of season a week for two weeks to clear it up.
    Starting with some leftover 3 inch tabs and have added six bags of the cal hypo over last two weeks.
    Then added 5 boxes 20 mule team borax and 5 lbs of soda ash and ordered a k2006C kit just now.
    Q. Add some of the bisufate from BioGuard that I have to reduce ph below 8 and add some more borax?
    2Q. What other testing capability do I need? Borate strips? Copper testing? Or will K2006C be enough?
    Plan to use bleach and/or 3 inch trichlor non-stabilized tablets if they can be found locally.
    Thanks in advance
    18k gal 28' Doughboy AG pool; 225# sand filter; 1 HP pump; well water. PF=6.7
