Re: Pool Cleaner Reviews
Older Aquabot that came with the pool. I had to replace the belts (multiple teeth missing) and the fine bag (due to rips) Not sure previous owner took care of it like they should. Comes with about a 50' cord which covers my 18x34 inground vinyl pool. Seems to love the deep end. Easily climbs the angled walls of the deep end but comes to a stop on the right angled walls of the shallow end and the steps. Doesn't like to reverse itself when it gets in trouble so I have to give it a hand. But as for cleaning it does an excellent job with the finer particles my sand filter seems to have trouble with. Also works well with leaves. The bottom suction is strong and it pumps water out of the top that helps aerate and circulate the pool water as it goes along. Has scrubber brushes front and rear that help clean as well. I would seriously consider this again, or dolphin or similar type of robotic cleaner. Most run anywhere from $600 (basic model) to over $1200 (remote control). The bag is easily cleaned with a water hose in 5 minutes and wrung out and hung up to dry. Parts are readily available from a number of sources.
18x34 22k gallon IG, Vinyl liner, Hayward sand filter, Hayward Chlorinator, Pentair Challenger 1hp pump, LA Spa.
