Thread: Losing just a little FC overnight
    Apr 2014
    SE Louisiana
    Default Losing just a little FC overnight
    I had some problems with FC staying at 1, so last night I used enough bleach to get it to 18ppm. I tested at about 7:30pm and it was 18ppm. I tested again at 7am this morning before the sun came up and it was 15ppm. So it did not lose a lot, although it was more than 1ppm that it lost. So in this case do I need to just bring it back up more tonight?
    My pool is around 21,000 and 15ppm was shock level so I guess it was still technically at shock level this morning. I am not sure if I need to add more bleach being it did lose 3ppm overnight and not just < 1ppm.
    Thanks everyone!!
    16x32 in-ground rectangle | chlorine pool | vinyl liner | k-2006 test kit
    Default Re: Losing just a little FC overnight
    Since you lost 3ppm overnight, I'd go ahead and shock it up again tonight after you test it. Then, a few hours after adding more bleach, test again so you'll have a number to compare it to in the morning to look for overnight drop.
  1. Loosing too much chlorine overnight
    By douge55 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-09-2011, 08:51 AM
  2. Liner slipped overnight! HELP!
    By ConnieStewart in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2010, 06:15 PM
  3. new water...overnight color change
    By PFPAM in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2007, 12:41 PM
  4. FC not holding overnight...
    By mariner09 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2007, 05:32 PM
  5. Holding chlorine overnight
    By AndieP in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-12-2006, 04:19 PM
