Results 1 to 10 of 11
Thread: Testing cya with 2006
    May 2013
    Concord,ca
    Default Testing cya with 2006
    I'm testing cya with my 2006 kit. Everything is ok, ch. is 3.0 but cya vile goes to the top with the water and its barely cloudy. So how do I get an exact reading? Thanks Dave G.
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Aug 2012
    Gilbert, AZ
    Default Re: Testing cya with 2006
    This indicates that your CYA is very low. The lowest reading the K2006 kit shows is 30, so if you're filling up to that mark and you can still see the dot you need more CYA (Stabilizer). Have you recently drained & refilled your pool?
    PebbleTec | 25k Gallons | Purex Triton Whisperflo pump | Magnetek Century Centurion 1.5HP | Hayward Pro Series S311SX Sand Filter | Taylor K-2006 kit
    May 2013
    Concord,ca
    no I haven't drained and refilled. I will probably put more stabilizer in tomorrow, hoping that will work
    May 2014
    Plano, TX
    How did you add stabilizer and when? If you poured it in the skimmer, it may take 4 or 5 days to completely dissolve.
    May 2013
    Concord,ca
    I put in a gallon of liquid stabilizer 2 weeks ago
    May 2014
    Plano, TX
    Ok, your good to go then.
    May 2013
    Concord,ca
    still don't know how to get a closer reading than the 2006. Closest it reads is 30. I go to a REAL pool store 3rd generation they only own one and I'll see if they can test it better
    No test can detect a CYA level lower than 30. If it has been two weeks since you last added stabilizer and you still don't have a reading, you can just assume that your reading is less than 30 and you need to add more. I would only add a dose that would add about 20ppm more, though. If your current reading is close to 30, that would put you at around 50ppm which would be a good reading.
    May 2013
    Concord,ca
    ok Watermom, I hear you but how much do I put in I could put in liquid again and that would be faster but if I put in powder it could take weeks. I don't know how much to raise from less than 30 to 50. Like at 13000 gallon what would be the formula for adding the amount?
    Adding 2 lbs. of granular CYA should add around 20ppm. It won't take weeks to dissolve but maybe a week. Or, if you prefer, use the liquid. Faster but more expensive. I can't comment on the proper dosing of the liquid, though, as I always use granular.
