Results 1 to 9 of 9
Thread: Ordering First Pool
    May 2014
    Joplin, MO
    Default Re: Ordering First Pool
    Bump for input on my idea to run the oversized 2-speed pump on low most of the time.
    BigDave's Avatar
    Sure! You may want to only use the low speed. There's alot of senanigans around HP ratings of above ground pumps - All manufacturers. It's telling that the impleller for that pump is listed as 1HP. It may not be soo badly oversized.
    May 2014
    Joplin, MO
    Thanks BigDave,
    Am I missing something regarding saltwater and pump/filter specs? None of the filters or pumps I looked at said anything about being safe for saltwater. If it is not a concern for the pump and filter I think I will go ahead with the Haward SWG I am looking at.
    May 2014
    Joplin, MO
    I read in the filter manual it was safe for salt. I went ahead and ordered the Hayward salt system that mounts to the return jet. Pool should be here this week and installed next. I hope to learn much more here on this site.
    . . . membership upgraded.
    If you are filling a small pool, you can get started with the Super Simple recipe, if you'd like: http://pool9.net/ssr/. Note that the SSR can ONLY be used on freshly filled pools, and ONLY for limited time period.
