Re: New here-Question about adding Epsom salts to Inground pool
That is exactly the opposite of what you would want to do to minimize scaling in the SWG cell. Epsom salt is magnesium sulfate so while the magnesium would not scale the way that calcium does, the sulfate produces a much harder to remove scale. If you wanted to minimize scaling through use of a different kind of salt, then you would want to get magnesium chloride instead.
However, there are other ways to prevent scaling in the salt cell such as proper control of pH, Total Alkalinity (TA), and Calcium Hardness (CH) levels and the use of 50 ppm Borates which it sounds like you have already added to the pool (either from a combination of borax and acid or from boric acid directly).
