Re: Help with exact dimensions
A 16' x 32' is normally a Doughboy brand size, not always but most of the time. This makes a big difference. If so, hopefully you have a Doughboy liner to go in it. Either way, you do not shape the pool to fit the liner, you shape the pool so that the end rails fit correctly so that all the top rails fit correctly. Oval pools with straps connecting the braces make it pretty hard to get wrong, so I assume you have no straps. On a Doughboy brand pool the distance from the front of the side brace, across the pool, to the front of the opposite brace is 15' 7 1/2".
It is a big help to know exactly what you are working with.
Later, Dennis
