Results 1 to 8 of 8
Thread: Trouble w/ vacuum head?
    Apr 2014
    NE Penn
    Question Trouble w/ vacuum head?
    When I try vacuuming with triangle shaped vacuum head, it won't sink to bottom as it normally does. I have to hold it down on bottom. If I release it; it rises to top..Seems like there's enough suction...Any ideas? thx
    Default Re: Trouble w/ vacuum head?
    Are you purging your vacuum hose of air COMPLETELY before plugging it into the skimmer? You hold it over the return to push all the air out, and move it underwater to the skimmer.
    Apr 2014
    NE Penn
    Carl, yes I've done that...I actually think the head is not heavy enough..Trying to find a way to add weight or buy another head...
    I must admit I'm having a hard time picturing it. Any head should sink and air must be captured somewhere that you're not purging. You are not by some chance using a "floating hose"--my Polaris 165 has one (haven't used the Polaris in years). Do NOT add lead weights to the head, though a small plastic-covered free weight or dumbbell could be zip-tied to it...just a thought. I wouldn't use an uncovered metal free weight though.
    Apr 2014
    NE Penn
    I tried pushing head down to bottom with just pole attached (no hose)...When I release, it rises back to top...That's why I suspect the prob is with head....It looks like a Hayward; but it's not...I purchased it at the end of last season..This is the first time using it... Shoulda bought a HAYWARD
    Apr 2014
    NE Penn
    Ok...Here's what I did: Took a sandwich bag and placed 4 oz sinker from my fishing tackle box and vinyl taped it to base of pole...Problem solved...Just need to check bag from time to time.
  1. manual cleaning vacuum head question
    By singingpond in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-07-2013, 05:18 PM
  2. Vacuum head recommendation
    By gwingard in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-09-2013, 10:55 AM
  3. In over my head???
    By Patti24 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2012, 01:41 PM
  4. New Vac head
    By Macrosill in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-25-2006, 07:19 PM
  5. New Vac head
    By Macrosill in forum Above-Ground Pool Construction & Repair
    Last Post: 07-19-2006, 08:20 PM
