Results 1 to 10 of 15
Thread: Help with test results and cloudy water
    Default Re: Help with test results and cloudy water
    You really need to give it more than 2 hours. When you raise pH (or adjust the TA) a lot of chemisty happens in the pool and it takes a while for things to stabilize. Wait at least 8 hours and then retest. 24 hours is better. If it hasn't moved then add more.
    Just my 2 cents.
    Thanks. The pool store tested my water today and ph is still low (6.8). CYA is up to 40. I'll test and add more borax tonight if needed. I'm also going to add some stabilizer.
    ~25,000 Vinyl pool
    Pure and Clear SWG; Hayward Pro Series filter
    Purex Triton Minimax+ Heater; Magnatek Centurion 1 hp pump; PCS Infinity 2000 Cover
