Results 1 to 10 of 11
Thread: Calcium and sodium question
    May 2013
    Concord,ca
    Default Calcium and sodium question
    I noticed bleach is sodium hypochlorite, my chlorine is calcium..any difference
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Calcium and sodium question
    Yes, different. Cal-hypo adds calcium as well as chlorine. Bleach (sodium hypochlorite) adds a little salt as well as chlorine. Both are fine as long as your calcium hardness level doesn't get too high. In that case, you wouldn't want to use cal-hypo.
    May 2013
    Concord,ca
    thanks for getting back
    Once they are dissolve in the pool they are fine, but never EVER mix them! (can you say "kaBOOM!"?)
    May 2013
    Concord,ca
    No Carl I was not going to mix just add slowly one at a time and wait a few between adding. Thanks much
    If you add bleach to gain chlorine, why would you want to add cal-hypo afterwards? As a source of chlorine, you wouldn't need to use them both on the same day. When I said that many people use both, I didn't mean in the same day as that is not needed. What I meant was that some people might use bleach most of the time and then only use cal-hypo occasionally instead of bleach or vice versa. Does that make more sense?
