Take Apart Pump To Fix Leak
Hi Gang. Hope everyone's winter is well! I wanted to fix a drip leak I've had in my pump for two years. Not sure of the brand, sticker says "Avalanche 4000" and specs say AC1000MXVT." It has three parts. 1: A "bucket" where the water enters in the front and goes through a skimmer-type strainer and exits to the rear. 2: A cylinder that shoots the water through the top onto the filter. and 3: The motor in the rear. It has a drip leak coming from the bottom of the center cylinder. Research of other posts suggest a possible bad gasket / o-ring / or sealer. But in order to open that section of the pump I must remove the front "bucket." It is held on with a 3-inch horseshoe shaped plastic clip. I'm not sure how to remove that. Do you imply lift it off? I don't want to snap it ((I've been known to do that!!) THANKS!
Steve Romo (6700g AG, Cartridge Filter)
