Results 1 to 9 of 9
Thread: Scale on Fiberglass Pool
    May 2014
    Hawaii
    Default Scale on Fiberglass Pool
    My pool service added Sodium Bicarbonate to my pool, and shortly thereafter, a gray coating appleared on the fiberglass surface. That was six months ago. It has gradually lessened, but is not gone. My pool guy says just wait.
    Any suggestions to speed up the process?
    Default Re: Scale on Fiberglass Pool
    The thing is, several things could cause that, but my first guess would be too much calcium in the water and adding the bicarb raised the Total Alkalinity so it started to scale.
    BUT
    That's impossible to tell without a full set of test figures.
    We always recommend, first, the Taylor Technologies K-2006 or K-2006C test kit, but a good, cheaper alternative is the K-Mart HTH 6-way drop test.
    While we will need tests for chlorine levels (preferably separate tests for FC--free chlorine, and CC--Combined Chloramines) and Stabilizer/CYA levels, what may confirm my initial guess is three tests:
    pH--remember HS chemistry?
    CH--Calcium Hardness
    TA--Total Alkalinity--NOT the same thing as pH
    Read the muriatic info page => http://pool9.net/ma/, then get a jug of muriatic. (Lowes, etc.)
    Pour a small amount of MA in a plastic bucket -- watch for fumes! Put the bucket next to the pool near a scaled spot. Wet the deck down, so acid splatters don't mark the deck; leave the hose running next to you, so you can quickly rinse away splatters.
    While wearing gloves and glasses, wet a clean plastic sponge (no residue to react with the acid, and no cellulose sponges!!) with acid. Take the sponge, and hold it against one of the scaly spots. If it fizzes or is removed, lowering your pH will accelerate scale removal.
    If that works, then read about lowering alkalinity, here: http://pool9.net/alk-step/
    Meanwhile, if you can, purchase a K2006 testkit. With the pool guy you've got, you need one so you an monitor his actions. http://pool9.net/testkits/
    May 2014
    Hawaii
    My pool guy has just provided the following readings:
    Ph: 7.0
    CA 300 ppm
    TA 30 ppm
    FC: 7.0
    He used a drops test kit, and I believe his readings.
    He wants to raise the TA to 120, suggesting we add 3lbs of Sodium bicarbonate. What do you think, Carl?
    Don't do it, if you still have scale!!
    May 2014
    Hawaii
    Carl, any comments from you?
    Hank,
    You've got our advice. It's up to you to decide who you trust: us, or your pool guy.
    Good luck.
  1. Stain and scale in a fiberglass pool
    By Poolrn in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2013, 12:02 PM
  2. white residue or scale in fiberglass pool
    By Poolhouse in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2013, 12:18 PM
  3. stain/scale on bottom of pool
    By bjseeberg in forum Dealing with Alkalinity and Calcium
    Last Post: 06-13-2012, 11:07 PM
  4. First pool, water is clear but fiberglass is stained and lots of scale
    By MountainStone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-15-2012, 11:14 PM
  5. Scale in a Saltwater pool
    By tbannister in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-08-2011, 09:16 AM
