Results 1 to 10 of 41
Thread: Filter / Pumps / New Pool
    Default Re: Filter / Pumps / New Pool
    If the other 87.5% ingredients are just water, then it is fine. It is simply a stronger concentration of bleach. If you are unsure if there are other things in there besides sodium hypo and water, then I would pass on it.
    May 2014
    Will avoid using the Star Shock as I have no idea what the "other" ingredients are. I am filling up the pool and added the bleach (2 doses) after 6 inches. I'm waiting for the water to get above the skimmer and I will turn filter on. Manual states to leave on for 6 hours.
    Water currently looks yellow. I will test sometime tonight after pool is near full with the 3 part test.
    Are you filling from a well or city water?
    May 2014
    City water
    Yellowish tinge to the water sounds like it could be metals. Look in the back of your toilet tank and see if there are water stains and if so, what color?
    May 2014
    The mark there is brown.
    May 2014
    Also, can someone point me in the right direction in how to read an hth 3 part tester. I tried the pH side. I inserted into pool to fill to top line, put in 5 red drops, closed top inverted and inverted back and the entire column was red. I either have high pH or I'm doing something wrong. Similar thing happened on the chlorine/yellow side.
