Closed Thread
Results 1 to 10 of 44
Thread: Argggghhhh!!!
    no1ford is offline ** No working email address ** Thread Analyst no1ford 0
    Default Re: Argggghhhh!!!
    ok-thanks.
    one more question-should I keep running the filter or shut it off and see if water clears? I haven't vacuumed yet.
    keep the filter running
    ok-will do. At least my water is blue and not brown! There always is an upside!
    TN.
    I know you are going crazy! I was there two years ago when I had a intex pool. You didn't mention if yours has the skimmer that hangs on the side. If it does, I would use a filter sock if you aren't already. Those intex pumps just take forever to clear the water. The pump never gave us any trouble as long as I was on top of my water. But once I got algae is was almost impossible to get it clear. Keep the pump on and clean or change the filter as often as you possibly can.
    Karen
    Karen
    18' AG
    what sock? I do have a side skimmer. This am -no change in water!
    ok-I did some reading and I put a nylon on the outside of my skimmer sleeve to filter through. It wouldn't fit nicely inside -so I thought I would try out first and see.
Closed Thread
