Closed Thread
Results 1 to 10 of 44
Thread: Argggghhhh!!!
    no1ford is offline ** No working email address ** Thread Analyst no1ford 0
    Default Re: Argggghhhh!!!
    what sock? I do have a side skimmer. This am -no change in water!
    ok-I did some reading and I put a nylon on the outside of my skimmer sleeve to filter through. It wouldn't fit nicely inside -so I thought I would try out first and see.
    ok-so I can see maybe 6 inches farther down and have a turqouise color. very pretty! I am just going to let the filter run for a few days and keep levels good and see if now with the nylon on if things filter through. I do have a very small pump-so maybe the days I was given is unrealistic. I will update when I have change!
    Downingtown, PA
    The best thing you can do is get that Chlorine into shock level and keep it there throughout the day.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    It had been at 10 + for two weeks, Can't I let it drop yet?
    Still looks the same! Blue and cloudy-I'll keep it the pump a running!
    Can I use bleach in my 18 x 48 intex pool? The pool store is out of chlorine. What do you use for ph plus and minus and clarifier?
Closed Thread
