Results 1 to 3 of 3
Thread: Jandy Activator wiring question - newbie
    May 2014
    Texas
    Default Jandy Activator wiring question - newbie
    Long-time pool owner.... new to the forum. I just had a Zodiac iAqualink controller installed. It replaced a 16-year-old Aquadyne Mini panel. The cables from the activators had the 3-pin connectors removed and replaced with some standard electrical terminals.
    We can put new 3-pin connectors on (had to go online and order-- couldn't find a local supplier). My question is the wiring order in the connector -- red, white and black. I am told if I get the white correct, the black and red will work either way. I might just have to flip the toggle switch on the activator.
    Any help would be appreciated.
    Default Re: Jandy Activator wiring question - newbie
    . . . membership upgraded.
    Sorry, but I can't help with your question. The only people likely to know the answer to that sort of question, right off the top of their head, are service guys who've worked on those units. That lets me out, and since I tend to be pretty harsh with pool guys who try to sell their stuff here, the concentration of pool guys here is low.
    PoolSpaForum.com is possibly your best bet for a question like that. Lots of spam, though.
    (I assume you have called Jandy? If you haven't gotten it fixed by July 4th, you might call back. Pool manufacturer customer service is in their "we are drowning", so CS guys are likely to blow off questions that aren't proper warranty questions. Later they won't be so busy.)
    May 2014
    Florida
    This guide here shows you How to Replace your Jandy Actuator hopefully this will help you out.
    Inyopools
  1. Dead heater, remote control, wiring jandy valves
    By jqgreen in forum Pool Equipment & Operations
    Last Post: 08-12-2012, 08:36 PM
  2. Wiring of Whisperflo, have a simple question.
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 05-19-2007, 06:49 PM
  3. Super Pump II Wiring Question
    By JWB in forum Pool Equipment & Operations
    Last Post: 04-01-2007, 10:41 AM
  4. wiring for a heat pump(new IG pool)question
    By freddyttt in forum Pool Equipment & Operations
    Last Post: 09-08-2006, 01:01 PM
