Results 11 to 16 of 16
Thread: Beginning of Converting
    May 2014
    Alabama
    Default Re: Beginning of Converting
    My pool is doing wonderfully!! Thanks for all of your help, plus the Taylor. We are on target! Don't forget me though because I may have more questions!
    Above ground 13,500 gallons sand filter
    Bamagirl
    May 2014
    Alabama
    3 parts combined chlorine
    PH 7.8
    akalinity 90
    is this a good place to be in the early morning at the beginning of a very sunny day?
    Bamagirl
    Not the 3ppm of CC! Ideally, you want that to be 0. Try the chlorine tests again. These testing video demos might be helpful.
    http://pool9.net/K2006-vid/
    Your pH and alk are fine.
    When you re-do the tests and re-post, please list FC and CC readings.
    May 2014
    Alabama
    what about 0.3 combined chlorine??? Ugh!
    PH 7.8
    akalinity 90
    Bamagirl
  6. #16
    0.3 CC is acceptable although I'm not sure how you got that reading. If you use a 10mL water sample, your readings are always in increments of 0.5 and if you use a 25mL sample, in increments of 0.2.
    (A CC reading of 0.5 or less is ok. If it goes over 0.5, then you'll want to take your chlorine up to your shock level.)
  1. Beginning of an algae problem...
    By Racker in forum Dealing with Algae & Slime
    Last Post: 08-01-2013, 04:16 PM
  2. Beginning the search for a pool builder.
    By pbdbk in forum In-Ground Pool Construction and Repair
    Last Post: 07-23-2013, 07:57 PM
  3. Beginning chemicals?
    By Pollysunshine in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2007, 03:49 PM
  4. The beginning
    By jetbtdrvr in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-15-2006, 12:21 PM
  5. Beginning the Bacuacil converson
    By clayw1963 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-20-2006, 12:40 PM
