Thread: sloping yard
    May 2014
    Default sloping yard
    having an above ground pool installed on a sloping yard, at some points we have to dig 3ft any tips and tricks after its done?
    Default Re: sloping yard
    . . . membership updated.
    May 2014
    Maryland
    I put up an above ground pool last summer. The pool encroached on a hill in the yard, making me have to dig out about 1 1/2 feet. I dug out about 12 inches wider to make sure i had room to manipulate the pool wall into place and it was barely enough space, but got the job done. When the pool was up and full, I lined the 'underground' portion of the pool wall with plastic sheeting (to keep dirt/rocks off the wall) and filled in the trench mostly with the dirt i removed, then a layer of landscape fabric, then a thin layer of river stone. That way most of the extra removed dirt had somewhere to go, and cheaper then filling all the way with stone
    10k gal 21" x 54' AG pool; 1.5HP Hayward pump; sand filter. PF=12
  1. Going to get Above Ground Pool - Have Sloping Yard
    By hannainnc in forum Above-Ground Pool Construction & Repair
    Last Post: 07-15-2012, 04:43 AM
  2. lighting around pool/yard
    By SS1304 in forum Pool Equipment & Operations
    Last Post: 05-17-2011, 08:06 PM
  3. Sand Filter & DE - backwash to yard
    By vchavez in forum Pool Equipment & Operations
    Last Post: 06-05-2009, 05:12 PM
  4. OK, let's pretend this is your yard...
    By philamom in forum Above-Ground Pool Construction & Repair
    Last Post: 08-16-2006, 01:16 PM
  5. What to do with ugly area in your yard? Here's an idea....
    By cruzmisl in forum General Interest
    Last Post: 06-20-2006, 10:37 PM
