water problems
we just set up our new AG pool a week ago. I followed the instructions as per our pool store. Add stabilizer, then shock and let run for a few days then add some pucks to the clorinator. Then wait another day and bring in a sample. Well the hardness was low (as expected) but the ALK was doing some weird stuff. They tried to test it but the sample turned yellow???? So they had me bring the hardness up from 20 and add some alk increaser. Well I tested it with my taylor kit tonight (just the alk and PH) Ph was a little low but as with our hot tub I try to get the alk in check and the PH usually falls into place. Well my Alk test went yellow again. I do the same as with my tub. And instead of going from green to red it gos from green to yellow? I am very confused. Any reason why? This is city water. My tub is usually low in ALk and Hardness and thats it.
- You may not post replies
- You may not edit your posts
Forum Rules
