How long ago did you open and was the CYA at opening as high as it was on closing? If not and you opened recently that could be the problem.
I ran the cya at 50 last year. Using Ben's test kit, the cya was still the same this spring. Dorie
Well, at least that eliminate biodegration of CYA as your problem!![]()
