Thread: Jacuzzi Tri_Clops filter
    May 2014
    GA
    Question Jacuzzi Tri_Clops filter
    I have an 8 year old Jacuzzi Tri-Clops.
    We have replaced the original cartridges with some generics. They have been working fine. The problem I'm starting to have is with leaks around the locking ring. I installed a new O-ring and the ring tightens easily to the stop position. When I start the filter up I get a very slow drip from the ring. I also noticed that the top of the filter "lifts" when the pump is turned on and settles back down when the pump is turned off (about 1/16 to 1/8 of an inch or less).
    Any ideas?
  1. Jacuzzi pool filter conversion kit?
    By jacuzzipoolman in forum In-Ground Pool Construction and Repair
    Last Post: 04-27-2012, 10:33 AM
  2. jacuzzi 190 L Filter Manual
    By sisie5 in forum Pool Equipment & Operations
    Last Post: 08-19-2006, 12:15 AM
  3. jacuzzi filter problem ?'s
    By packerfan in forum Pool Equipment & Operations
    Last Post: 05-24-2006, 07:46 PM
