Closed Thread
Results 1 to 10 of 15
Thread: electrician costs for new vinyl pool?
    Default electrician costs for new vinyl pool?
    About what should the electricians bill be to install electrical power and bond vinyl pool. 40' run from house to pool pad, @ pad, pump outlet for polaris pump, switch for light, and convience receptical. I,m looking for general figures. I know there are alot of specifics that change price. I just recieved a quote of 1800 for labor and 800 for parts. (2600 total seems high.) Labor was figured @ 16 hrs x 110 per hr. (75 for electricican and 50 for helper per hr) Any input would be helpful thanks chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    North Texas
    Default Re: electrician costs for new vinyl pool?
    Did he give you an parts list that he will be using? I'm in the process of running the electrical to my pool. I have a 60ft run to make, that's not counting the run across my attic. Conduit to run it under ground, a pool timer and GFIC box at in my garage. My parts so far total approx $400. Then again, i'm not an electrician. I'm an electronic technician, but not an electrician. Maybe i'm missing something.
    Morris, IL
    If it is an electrician, then I bet that there is conduit involved, which is only right, metal costs more I bet, not sure though I always use plastic. Plus, a penetration through the foundation into the basement? An interior run in conduit to the main circuit breaker, pull boxes, and outdoor recepticals.
    But personally, I think that it is very expensive, do it yourself, at least run the conduit and mount the boxes, it really is not hard. Electricity is pretty easy, but you could save alot of money by doing some of the work yourself, even digging could knock alot off of the bill. As it is, I am a tightwad, and I do all work myself, from fixing cars, to computers, to all types of construction.
    Here in NJ I just paid an electrician $850 to run conduit and wire roughly 50 feet from the house. This included wiring the outlet for the filter, new light in the pool and switch to turn the light on/off inside the house. This also included them digging the trench to run the line.
    tundraSQ is offline Registered+ Thread Analyst tundraSQ 0
    Quote Originally Posted by us7sail
    75+50 =125 not 110.(maybe they gave you the good guy discount)..and yes 16 man hours to do that job sounds like ALOT to me. Are you paying them to dig the trench and lay the conduit? If so I suggest you do that part yourself and save about half the labor. I would also get other quotes.
    Joliet
    With a price that high...
    It sounds like the person doesn't want the job. The reason could be that he/she already has too much work...or simply does not want to do this particular job (usually due to size or type). So...the alternative is they price the job so high...that they either don't get it...or if the person agrees...the price make it worth their aggravation.
    I'd get at least two more bids.
    dan
    thanks for all the replys.
    The electrician who gave the bid says he does pools all the time so i would have thought his time would have been less than the 16 hrs proposed.(especially with two people) The main trench is already been dug to the pad and that run is straight and right to the main box about 45' away. The bonding to light coping ladder and stair rail is the only other real issues. convience receptical will be at the pad. I do not object to material cost so much ($700) but $1800 for labor sound crazy. this AM another guy gave a bid for 2500. I am very much thinking of getting the code book and doing it my self. (The whole thing will be inspected any way an I am in no hurry)I have run many circuits before. I did not think prices would be that out of wack. Thanks chris
    Indiana.
    You can quite easily do it yourself. The big problem is bonding the rebar or mesh in the pool deck. I don't honestly think there is an easy or effective way to do this. If you choose to do it, talk to your inspector to find out what he looks for. Many cities have a handout describing their local rules and inspection points.
    Rehoboth, MA
    Yes - definitely check with your inspector. My town requires that a licensed electrician pull a separate permit and install the electrical outlet and bonding wire.
    It also wouldn't hurt to ask the electricians if you could do some of the prep work to reduce the labor involved. I did some of the prep work myself but didn't consult with my electrician beforehand (I initially thought I could do the job myself) so what he usually does was different from what I did (I had the outlet box mounted low - about 1 ft off the ground - and he usually has them mounted higher - about 3 feet. He had to dig up the ground and cut the conduit and pull new wire etc). If I had talked with him beforehand, I could have done it the way he wanted and saved labor time.
    Peter
    You did not say (or I did not see) where you are located, as rates vary highly by region. I am in Northern NJ and I just pulled out the paperwork from when I did my pool in 1997 and I paid $1,735 then, which was the best price I could find. I had some estimates as high as $4,000.
    Now our scope may have been slightly higher than yours. We put in a 60amp sub-panel which was run about 120' underground to our main house pannel. We have 220 running to the pool pump. polaris booster pump and heatpump, plus 110v to an electric outlet, pool lighes and an outside spot light. The entire pool was bonded as well and there are timers for each of the pumps. Price included all work and materials.
    Be forewarned that electrical codes and inspectors vary all over the map. The guy I used specialized in pool work, but did most of his work in a town other than mine. When he had to connect the two timers together rather than running a conduit out the bottom of one with a "U" shaped pipe and then into the other he decided to go straight down and put the "U" underground to make the piping look nicer. The inspector failed him as he said all conduit must go at least 18" underground. Did not matter that this did not need to be in the ground, he made him either raise it out of the ground or go deeper. Point is, when you get the pricing make sure you have wording in it that specifies it must meet code and the contractor (not you) is responsible for any extra cost that the inspector may insist on.
Closed Thread
  1. repainting pool costs??
    By fhorta in forum In-Ground Pool Construction and Repair
    Last Post: 07-18-2014, 04:48 PM
  2. Need a Plumber and Electrician
    By steelbone in forum General Interest
    Last Post: 06-13-2013, 11:06 AM
  3. Repair Costs for IG Pool???
    By newbie2pools in forum In-Ground Pool Construction and Repair
    Last Post: 09-17-2008, 11:17 PM
  4. Electrical costs for my pool
    By rpoldervaart in forum Pool Equipment & Operations
    Last Post: 07-20-2006, 01:30 PM
  5. DIY Pool Construction Costs
    By Blinger in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2006, 08:06 PM
