Results 1 to 10 of 11
Thread: Geez pool is still cloudy.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Geez pool is still cloudy.
    6.8 is the lowest pH level a lot of kits will show (probably yours too??), so it could be a lot below 6.8 and that's why you're not showing an increase.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Yeah I was thinking that and when i took a sample of pool water into my pool store...they said my Ph was 7.1. I added a box of borax since then and I'm still reading 6.8. Maybe I'll try to find my test strips and see what they think. I'll take another sample to the pool store and see if they get a higher reading than 7.1.
    just an update today i could see the bottom clearly, so i did the some sweep and vacuum. Got most of the dead algae out. Pool is looking blue thanks for the help.
