Can you post (or email me) complete hi-res pictures of the label?
I don't understand how 99% dichlor can be 39% chlorine, and those labels are federally regulated, so their ability to play marketing games is somewhat restricted.
went to the site of Cameo Chemicals. I first googled the dichloro-- and it game me the site. This site has the msds as well as other names listed. When I went to the site I didnt immediately get it but the google did and sent me to the same site..so figure. When you get there you scroll down to the chemical in question. Also theit email is [email protected]. Hope that's what you want
13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
I only trust the k-2006 titration is better for me
1. [email protected]
2. "Cameo Chemicals" is really a NOAA spill database, here: http://cameochemicals.noaa.gov/
3. The reference to 39% dichlor is not a reference to a product, but to a potential condition. Supposedly, dichlor at available chlorine concentrations BELOW 39% behaves differently than dichlor at concentration above 39%.
Well, maybe. But it's NOT talking about any specific product.
4. The database has some significant errors and omissions. It does correctly recognize, for example, that cal hypo and cyanuric acid react badly together. But it lists hydrogen bromide and sulfur dioxide as potential by-products. Considering that there is no sulfur or bromine in either cyanuric acid or dichlor, that's a rather remarkable outcome.
It also claims that dichlor and cyanuric acid react badly together with each other. I'm skeptical. We'll see. But I'm pretty sure that if they DO react, you won't have any hydrogen bromide (again) as a byproduct!
I don't think the CAMEO site is going to help you much. The entry in CAMEO you are seeing is for SODIUM DICHLORO-S-TRIAZINETRIONE and SODIUM DICHLORO-S-TRIAZINETRIONE DIHYDRATE with greater than 39% available chlorine.
I found the MSDS for the product you mentioned "ClearView shimmer n shock" on the manufacturer's website and it indicates (may be out of date) that it is undiluted dichlor. It is fine to use in your pool to chlorinate and add CYA.
I'm guilty again of "simul-post"
ok I'll use it but I will probably just stick to chlorine as all these different chemicals leave me a bit perplexed as after you looking at the ingredients is something I would know little in finding out the percentage. Thank you everyone it's very much appreciated Dave G.
This actually isn't complicated. This MSDS indicates that the Oreq ClearView® shimmer n shock product is 100% Sodium dichloro-s-triazinetrione which is what we normally call Dichlor. The following are the types of chlorine and their side effects in terms of what else they add to the water (for salt, this includes the resulting salt when the chlorine is used/consumed).
Type of Chlorine . FC CYA CH Salt . Typical Dosage per 10,000 gallons per FC
Trichlor ................ 10 . 6 ... 0 ... 8 .. 14.6 oz. (109 grams)
Dichlor ................. 10 . 9 ... 0 ... 8 .. 24.1 oz. (181 grams)
.................................................. ... for Dichlor Dihydrate
Calcium ............... 10 . 0 .. 7-8 10-12 20.7 oz. (155 grams)
Hypochlorite ................................... for Cal-Hypo 65%
Sodium ................ 10 . 0 ... 0 .. 17 . 102 fluid oz. (800 ml)
Hypochlorite ................................... for 12.5% (trade) chlorinating liquid
Lithium ................ 10 . 0 ... 0 .. 17 . 38.3 oz. (286 grams)
Hypochlorite
Chlorine Gas ......... 10 . 0 ... 0 ... 8 .. 13.4 oz. (100 grams)
Saltwater Chlorine . 10 . 0 ... 0 ... 0 .. N/A
Generator
Trichlor and Dichlor are known as "stabilized chlorine" because they have Cyanuric Acid (CYA) in them. Trichlor is usually in a slowly dissolving puck but is also sold as granular and it is quite acidic (low pH). Dichlor is granular. Cal-Hypo is usually in powdered form and increases Calcium Hardness (CH). Sodium hypochlorite is what is in chlorinating liquid and in bleach and is what we normally recommend as the common source of chlorine if you aren't intending to raise CYA or CH. Lithium hypochlorite is powdered but is very expensive. Chlorine gas is not used in residential pools except by a few pool services. A saltwater chlorine generator is fairly common in residential pools and generates chlorine from the salt in the pool.
WOW I keeping this info! thanks so much for taking the time to research Dave G. I still think you folks are geniuses. Thank You
I'm going to study this as I need to really master my chemistry as ....ok this is low.....so why...... look at the chemistry not just blindly dump chemicals in and hope for the best. I can stay on top of this so do it. Thank you so much
