Results 1 to 10 of 30
Thread: di chlor question
    Default Re: di chlor question
    This actually isn't complicated. This MSDS indicates that the Oreq ClearView® shimmer n shock product is 100% Sodium dichloro-s-triazinetrione which is what we normally call Dichlor. The following are the types of chlorine and their side effects in terms of what else they add to the water (for salt, this includes the resulting salt when the chlorine is used/consumed).
    Type of Chlorine . FC CYA CH Salt . Typical Dosage per 10,000 gallons per FC
    Trichlor ................ 10 . 6 ... 0 ... 8 .. 14.6 oz. (109 grams)
    Dichlor ................. 10 . 9 ... 0 ... 8 .. 24.1 oz. (181 grams)
    .................................................. ... for Dichlor Dihydrate
    Calcium ............... 10 . 0 .. 7-8 10-12 20.7 oz. (155 grams)
    Hypochlorite ................................... for Cal-Hypo 65%
    Sodium ................ 10 . 0 ... 0 .. 17 . 102 fluid oz. (800 ml)
    Hypochlorite ................................... for 12.5% (trade) chlorinating liquid
    Lithium ................ 10 . 0 ... 0 .. 17 . 38.3 oz. (286 grams)
    Hypochlorite
    Chlorine Gas ......... 10 . 0 ... 0 ... 8 .. 13.4 oz. (100 grams)
    Saltwater Chlorine . 10 . 0 ... 0 ... 0 .. N/A
    Generator
    Trichlor and Dichlor are known as "stabilized chlorine" because they have Cyanuric Acid (CYA) in them. Trichlor is usually in a slowly dissolving puck but is also sold as granular and it is quite acidic (low pH). Dichlor is granular. Cal-Hypo is usually in powdered form and increases Calcium Hardness (CH). Sodium hypochlorite is what is in chlorinating liquid and in bleach and is what we normally recommend as the common source of chlorine if you aren't intending to raise CYA or CH. Lithium hypochlorite is powdered but is very expensive. Chlorine gas is not used in residential pools except by a few pool services. A saltwater chlorine generator is fairly common in residential pools and generates chlorine from the salt in the pool.
    May 2013
    Concord,ca
    WOW I keeping this info! thanks so much for taking the time to research Dave G. I still think you folks are geniuses. Thank You
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    May 2013
    Concord,ca
    I'm going to study this as I need to really master my chemistry as ....ok this is low.....so why...... look at the chemistry not just blindly dump chemicals in and hope for the best. I can stay on top of this so do it. Thank you so much
    I'm updating the table to improve formatting and to add columns on the effects on pH and TA after accounting for chlorine usage/consumption:
    Type of Chlorine . FC CYA CH . pH . TA . Salt .. Typical Dosage per 10,000 gallons per FC
    Trichlor ................ 10 . 6 ... 0 ... -- .. -7 ..... 8 .... 14.6 oz. (109 grams)
    Dichlor ................. 10 . 9 ... 0 ... - . -3.5 .... 8 .... 24.1 oz. (181 grams)
    .................................................. ..................... for Dichlor Dihydrate
    Calcium ............... 10 . 0 .. 7-8 .. 0 ... 0 . 10-12 . 20.7 oz. (155 grams)
    Hypochlorite .................................................. .. for Cal-Hypo 65%
    Sodium ................ 10 . 0 ... 0 ... 0 ... 0 .... 17 ... 102 fluid oz. (800 ml)
    Hypochlorite .................................................. .. for 12.5% (trade) chlorinating liquid
    Lithium ................ 10 . 0 ... 0 ... 0 ... 0 .... 17 ... 38.3 oz. (286 grams)
    Hypochlorite
    Chlorine Gas ......... 10 . 0 ... 0 .. --- . -14 ... 8 .... 13.4 oz. (100 grams)
    Saltwater Chlorine . 10 . 0 ... 0 ... 0 ... 0 ..... 0 .... N/A
    Generator
    I show the hypochlorite sources of chlorine as being pH neutral, but they do have a small amount of excess lye (or equivalent) in them so slightly raise the pH, but the main source of pH rise in pools using these chlorine sources is outgassing of carbon dioxide.
    May 2013
    Concord,ca
    all typed and entered in my Pool Care binder. Thanks much
    Chem_Geek's very helpful table, in a little different form:
    May 2013
    Concord,ca
    Is there a way this can be made available out in the open for everyone....like before you ask...CHECK THIS OUT!! This is super great! looks like bleach and cal hypo are the non invasive way to go for just raising chlorine other than salt
