Results 1 to 10 of 10
Thread: New Pool
    ajb8898 is offline Subscriber Thread Analyst ajb8898 0
    May 2012
    South Carolina
    Default New Pool
    Hi, all. So, we bought a new above ground pool this year after our 18 year old one bit the dust last fall. I need help getting it all set up. The pool should be filled up with city water by this evening. Can you help me calculate how much chlorine I need to raise it 1ppm?
    Our new pool is still 18x33 oval but it's 52" instead of 48" tall. We have the same pump as noted in my signature.
    What do I need to do to get it initially set up as well? Please point me to a post if this is covered somewhere. Thanks as always!
    15K gal AG oval w/ Hayward sand filter; Taylor K2006C
    15'x30' oval 15K gal AG pool; bleach; Hayward sand filter; Hayward pump; 24hrs; Taylor K2006C; utility water; summer: ; winter: ; iPhone; PF:8
    Default Re: New Pool
    You might want to use the Super Simple start up recipe that you can find in my signature below. That is a good way to get started. Congrats on the new pool!
    (By the way, I think your volume is more like 14K. 52" walls make the water level about 46-48" deep since the pool is not filled to the top of the wall. You can edit your signature by clicking on the tab in my signature below.)
    Glad to see you back around this year!
    May 2012
    South Carolina
    Thanks!
    I was a little confused about the start-up. It mentions using dichlor. I haven't used that in the past. Should I be?
    You don't have to but it is an easy way to start up a freshly filled pool since it adds needed CYA as well as chlorine. Once you get your CYA level built up to where you want it, then you can just switch to using bleach. If you don't want to use dichlor, you can just add some CYA separately and just use bleach from the get go. Either way works.
    May 2012
    South Carolina
    Ah, ok. That makes sense now. What is a preferable target for CYA?
    Most people like around 50. Some places that are extremely hot and sunny seem to be better with it a little higher. But, I'd start with around 50ppm. If you find that you are having trouble maintaining adequate chlorine levels throughout the day, you can always bump it up later. Just remember to keep your chlorine in the proper range for whatever CYA level you have so you can avoid algae. (Take a look at the Best Guess Chlorine Chart in my signature below for the correlation between CYA levels and needed chlorine levels.)
