Have you added ANYTHING in the last 2 weeks except chlorine, stabilizer and baking soda ("alkalinity")?
If not, then you can try using a floc to settle the algae, but ONLY if you can 'vacuum to waste'. Do NOT do this if you've used other chemicals; instead, tell us what you've used. Do not do this if you can't vacuum the algae OUT of the pool.
Otherwise:
1. Get enough bleach (or liquid chlorine) to maintain your chlorine levels with the pump off.
2. Put the pump on "RECIRCULATE" if you can; otherwise, turn the pump off. Brush the pool COMPLETELY. If the pool turns green from piles of algae, add chlorine till it goes back to blue or gray.
3. Once the pool is brushed and blue. Check your chlorine. If it's more than 10 ppm, wait. Meanwhile purchase a bottle of what ever floc, your PaP store says works best for them with dead algae. Once the chlorine is below 10, add it following instructions.
4. TURN YOUR PUMP OFF, and leave it off at least 24 hours, to see if the algae will settle. Continue to add chlorine, as need to maintain adequate levels. If the algae seems to be settling wait up to 72 hours.
5. Once the algae has settled, vacuum it to waste, and the restore normal pool ops.
