Results 1 to 10 of 29
Thread: Chlorine and pH problems following missing stabilizer
    Default Re: Chlorine and pH problems following missing stabilizer
    Use muriatic acid to lower your pH to near 7.0, and just keep it there.
    http://pool9.net/ma/
    If you can aerate, that will not only help lower the TA, but will help remove some of the combined chlorine compounds that are forming.
    Also, you need to add 6 gallon doses of PLAIN 8% bleach, each evening. With CYA = 300 ppm, a *normal* chlorine level is 15 ppm; 'shock' is 30 ppm or more. You'll need to get the chlorine level up above 20 ppm. Be sure to use the 10ml test sample with the K2006 (each drop = 0.5 ppm). Otherwise you'll use up your chlorine test drops too fast.
    You might hold the record for the highest CYA award. I can't remember another pool that we have had on here recently with a CYA level that high! Thank you, pool store!!
    May 2014
    Pennsylvania
    That sounds good. A question though, if the chlorine is well above 20 ppm in the evening, will we still have to add the 6 gallons of bleach that day?
    18k gal IG vinyl rectangle; Hayward Super pump; Hayward DE filer. PF=6.7
    How much more chlorine you'll need to add, depends entirely on how much partially degraded CYA goo is left.
    You can run a chlorine demand test to find you, if you like: http://pool9.net/bucket-demand/
    May 2014
    Pennsylvania
    Working on lowering the pH...about half way there. Getting some pretty foam with the aeration though. Should we be concerned about that? Chlorine seems to be holding high really well. Will try to fit a demand test in. Was still 27 ppm this morning.
    Is it ok to start using our heater?
    Is it ok to cover, or will the high chlorine eat the new solar cover?
    Last, we were thinking about trying to start chipping away at the CYA with a 25% drain. We realize this will not have a profound immediate effect...but if we never start moving toward a healthier level, we may never get there. I would consider a larger drain, but I don't feel our pool could withstand it as we have a lot of ground water in our yard. I have yet to find an expert in this area of Pennsylvania who could help us. Thoughts?
    Quote Originally Posted by Cstaines View Post
    It probably indicates some remaining unoxidized 'goo'; while this is the case, your water may be unpleasant to swim in. The solution to most of these issues is sustained high chlorine + sunlight.
    Not with these numbers:
    pH 7.6
    Alkalinity 320 ppm
    Calcium Hardness 220 ppm
    You'll scale up the inside of your heater core badly.
    No, you need the sunlight, to help break down the 'goo'. It won't hurt the pool to cover at night, or on rainy days. BUT, as that 'goo' is oxidized, it will tend to form volatile chlorinated by-products. These will evaporate . . . OR accumulated under the cover, if the pool is covered. These sorts of gases CAN damage plastics.
    I think you don't realize how many times you'd have to drain 1/4 of the pool in order to have an effect. The chart below shows the steps it would take to get below 300 ppm, draining in increments of 10% up to 25%:
    However, if you want to go ahead and try, FIRST dig a post hole on the LOW side of the pool, as close to the pool as you can get. Dig it 1 foot deeper than you intend to drain the pool. (ie, drain 1ft; dig 2ft hole). Cover the hole and wait 24 hours. If it's dry, you're relatively safe. If not, don't!
    Keep in mind that this does NOT guarantee that you won't damage your liner by draining!
    May 2014
    Pennsylvania
    Ok...you guys are obviously thinkers and willing to think outside the box.
    My husband and I were trying to come up with a way to drain the existing water while adding new water in order to maintain pressure on the liner (walls). Would it be possible to place a large winter cover on top of the existing water, keeping the syphon underneath of it...start adding water to the top while syphoning water from the bottom?
    What numbers would be acceptable to run the heater?
    I am really trying to remain optimistic about this whole thing, but I have to be honest, it is all very overwhelming. We have a graduation party at our house in two weeks. Crappy cold water that nobody can (or would want to) swim in. The college tuition payments have already started and money is becoming an issue. We have depleted two Walmart bleach supplies (perhaps that is another award we can hold along with the highest CYA ever). I do realize how many drains this will take, but if we don't drain, when will it ever get better??? When will we be able to enjoy he pool instead of just look at it?
