That sounds good. A question though, if the chlorine is well above 20 ppm in the evening, will we still have to add the 6 gallons of bleach that day?
18k gal IG vinyl rectangle; Hayward Super pump; Hayward DE filer. PF=6.7
How much more chlorine you'll need to add, depends entirely on how much partially degraded CYA goo is left.
You can run a chlorine demand test to find you, if you like: http://pool9.net/bucket-demand/
Working on lowering the pH...about half way there. Getting some pretty foam with the aeration though. Should we be concerned about that? Chlorine seems to be holding high really well. Will try to fit a demand test in. Was still 27 ppm this morning.
Is it ok to start using our heater?
Is it ok to cover, or will the high chlorine eat the new solar cover?
Last, we were thinking about trying to start chipping away at the CYA with a 25% drain. We realize this will not have a profound immediate effect...but if we never start moving toward a healthier level, we may never get there. I would consider a larger drain, but I don't feel our pool could withstand it as we have a lot of ground water in our yard. I have yet to find an expert in this area of Pennsylvania who could help us. Thoughts?
It probably indicates some remaining unoxidized 'goo'; while this is the case, your water may be unpleasant to swim in. The solution to most of these issues is sustained high chlorine + sunlight.
Not with these numbers:Is it ok to start using our heater?
You'll scale up the inside of your heater core badly.pH 7.6
Alkalinity 320 ppm
Calcium Hardness 220 ppm
No, you need the sunlight, to help break down the 'goo'. It won't hurt the pool to cover at night, or on rainy days. BUT, as that 'goo' is oxidized, it will tend to form volatile chlorinated by-products. These will evaporate . . . OR accumulated under the cover, if the pool is covered. These sorts of gases CAN damage plastics.Is it ok to cover, or will the high chlorine eat the new solar cover?
I think you don't realize how many times you'd have to drain 1/4 of the pool in order to have an effect. The chart below shows the steps it would take to get below 300 ppm, draining in increments of 10% up to 25%:Last, we were thinking about trying to start chipping away at the CYA with a 25% drain.
However, if you want to go ahead and try, FIRST dig a post hole on the LOW side of the pool, as close to the pool as you can get. Dig it 1 foot deeper than you intend to drain the pool. (ie, drain 1ft; dig 2ft hole). Cover the hole and wait 24 hours. If it's dry, you're relatively safe. If not, don't!
Keep in mind that this does NOT guarantee that you won't damage your liner by draining!
Ok...you guys are obviously thinkers and willing to think outside the box.
My husband and I were trying to come up with a way to drain the existing water while adding new water in order to maintain pressure on the liner (walls). Would it be possible to place a large winter cover on top of the existing water, keeping the syphon underneath of it...start adding water to the top while syphoning water from the bottom?
What numbers would be acceptable to run the heater?
I am really trying to remain optimistic about this whole thing, but I have to be honest, it is all very overwhelming. We have a graduation party at our house in two weeks. Crappy cold water that nobody can (or would want to) swim in. The college tuition payments have already started and money is becoming an issue. We have depleted two Walmart bleach supplies (perhaps that is another award we can hold along with the highest CYA ever). I do realize how many drains this will take, but if we don't drain, when will it ever get better??? When will we be able to enjoy he pool instead of just look at it?
I can walk you through the process of managing a HiC2 pool -- high CYA & high chlorine. It shouldn't cost any more (and may cost less) than running in the ordinary way.
There is very little I can do in the way of a quick fix:
+ you can not safely drain and refill your pool, without hiring a professional to set up suction to hold the liner in place while the pool is drained.
+ even then, you can not drain your pool now, because the ground is wet.
+ you can do a 'drain in place' but you'll need a winter cover that is 15 - 20 feet wider AND longer than your pool. It will probably take a week, and when your done, the water temp will be whatever your fill water's temp currently is -- probably colder than it is now.
+ without knowing your fill water's condition, I have no idea what your TA and CH would be at that point, but currently those levels are too high for a heater.
+ there is a way to 'warm' the pool a little (3 - 4 degrees) assuming your current liner is light colored, by laying a large piece of black plastic on the bottom.
There is an option you could consider. Solar covers aren't that expensive -- certainly less than the cost of 2 weeks gas heat on a cold pool. If you're willing to sacrifice the cover, you could lower the pH some, keep the chlorine high, and begin aerating. Doing this would allow you to strip BOTH excess TA and the volatile oxidation products that are forming. It might damage your cover -- or it might not.
You'd need to order this fitting (after verifying that you can fit it into an existing return socket):
http://www.amazon.com/exec/obidos/AS...2/scouscho-20/
Using this fitting would allow to rapidly and effectively aerate your pool, even with the cover in place.
PoolDoc / Ben
