Results 1 to 8 of 8
Thread: Low water at pump
    May 2014
    North Carolina
    Default Low water at pump
    I just had a new above ground 18 x 40 x 54 pool installed. The pool is filled to its correct capacity. I'm using a 2 speed 1.5 hp pump and a Hayward Pro Series sand filter. Here is my problem:
    + After running the pump on LOW for an hour (+ or -), the strainer basket just before the pump is virtually empty of water....
    + If I run the pump on HI, the strainer basket is empty of water in a minute or two. The skimmer opening is still full of water.....
    +If I remove the skimmer basket up at the skimmer opening, everything works fine on either Hi or Low speed.....
    Is my basket at the skimmer not letting enough water through???? What do i do about that????
    Thanks!!!
    BigDave's Avatar
    Jul 2010
    New Jersey
    Default Re: Low water at pump
    Is the skimmer sucking air in? I keep a good size (a little smaller than my fist) rock in the skimmer basket to break up the vortex.
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
    May 2014
    North Carolina
    No, the skimmer never runs out of water or sucks air.
    I only run out of water at the basket near the pump. There are no leaks anywhere between the skimmer and the pump. As I said above, if i take the basket out of my skimmer, everything works normally with the pump on either Hi or Low....
    May 2014
    Wisconsin
    I was having the same issue. I realize that my impeller locking screw had loosened and backed out. You may need to replace that or tighten it up.
    Sounds like you may have 2 problems:
    1. Somehow, your skimmer basket is obstructing the flow. This shouldn't happen if it's (a) clean and (b) the right basket, so I don't know how it's occurring.
    2. If you are getting air in the pump basket, you have a suction leak. Period. If you didn't have a leak, you wouldn't have air. But if you have a SMALL leak, it won't show up on a flooded suction pump (below water level) UNLESS something obstructs the flow upstream of the leak location.
    The most common locations for a suction leak are the pump strainer lid gasket, and the point where the piping is connected to the pump. BUT a suction leak can be *anywhere* between the pool and the pump.
    May 2014
    North Carolina
    OK, I think I have a solution. The skimmer at the pool is brand new, it came with the new pool that was installed 2 weeks ago. There are absolutely NO leaks between the pool and the pump. As I posted above, everything is fine when the basket is removed from the pool skimmer.... So, I put a plastic spacer under the skimmer basket that was about 1/4 inch thick....a tiny bit of improvement, but not great. Then, I brought the spacer up to a half inch thick.... Much better, but still not 100%.... So I increased the spacer to 3/4" and PERFECT!!! So, now with the skimmer basket in place, I have plenty of water in the basket of the pump...no air and everything works "normally" on either high or low speed. The culprit was the skimmer basket itself. The skimmer basket has VERY fine holes in the bottom... When the skimmer basket is seated all the way down, it only lets water flow through the holes in the bottom, NOT through the holes in the sides..... When I raise the basket up by 3/4 of an inch, water flows through all the holes in the basket and water flow is perfect! Hopes this helps someone else.....
  1. Pump Pot Has More Air Than Water
    By NullQwerty in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2008, 11:06 AM
  2. Pump not pulling any water
    By rqbanerjee in forum In-Ground Pool Construction and Repair
    Last Post: 08-06-2006, 09:38 PM
  3. No water flow at pump
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 02:24 PM
  4. No water flow at pump
    By vinouspleasure in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-11-2006, 08:11 PM
  5. pump for well water
    By newtopools in forum Above-Ground Pool Construction & Repair
    Last Post: 06-08-2006, 10:10 AM
