Thread: Dimensions of impeller locking screw
    May 2014
    Wisconsin
    Default Dimensions of impeller locking screw
    Trying to figure out dimensions for the pentair superflo impeller locking screw. Product # 355389 please help, driving me nuts not having pool up and ready.
    Default Re: Dimensions of impeller locking screw
    . . . membership updated.
    Sounds like you are trying to get the standard fastener dimensions for that screw? If so, I've *never* seen a pool manufacturer supply that sort of data. I've occasionally purchased fasteners and O-rings as standards, rather than OEM, but I've had to carry the original part with me to an industrial supply house, and physically match OEM part to the standard part. I will note that impeller screw often seem to be specials, rather than standard parts. The threads are probably standard (except for the left-hand screws!) but the heads are not.
    FYI, your part is #21 on this drawing:
  1. Need dimensions from someone with Intex Ultra Rectangular pool.
    By zanemoseley in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2011, 03:19 PM
  2. Dimensions of the pool Pilot manifold
    By skipcoon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-16-2008, 11:22 AM
  3. Liner/Pool dimensions
    By markeast in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2006, 11:36 AM
  4. Autopilot dimensions and pump control
    By jacksonlui in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-22-2006, 04:14 PM
