Re: debating on how to level ground
I am in the same boat. I used a sod cutter to get the sod out, but the blade follows the front wheels. So, as the ground raises, so did the blade.
I have resigned myself to the old shovel methond. It sucks as there is no shade and my ground is kinda hard clay.
Is there a better way? I was thinking of getting the sod cutter again, and setting the blade to a deeper depth, and just raising the handle to 'manually' set the depth. But this would be tricky and once you dig out too deep, that spot is messed up.
So to add to Jimmyz queston:
Is there an easier way to level a site (I personally have to remove about 4 inch on one end to be level with the other. Pool is 15x18 butress free oval)
How smooth do you guys make your final site. How do you get the shovel gouges out? Just keep detailing it with the shovel?
I know you aren't supposed to build up ground. If I have an area I dug a inch or two too deep (Just an area, say 6x8 inch) can I hand tamp some soil back, or is that against the rules :-)
Man, I hope everyone is right and this is the hardest part of the build
Thanks !
